Civil 3D Forum
Profile view band style question...
6 REPLIES 6
373 Views, 6 Replies
Is it possible to have the profile view band NOT show text when no relevant information exists in that station range? (Please see attached PNG file.)
Thanks.
6 REPLIES 6
Jay_B
I'm not seeing any way to turn off or hide prefix text when typed into the Text Component Editor for the FG & EG elevation text.
If I add prefix text to the Band I see the same behavior here.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
kcobabe
Adding an if then expression should do this with ease.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Jay_B
No expression option for Profile Bands though AFAIK.
C3D 2018.1
C3D 2016 SP4
kcobabe
in reply to: Jay_B
There is you just have to fool the program 😉
You build it in one of the other compartments (in this case I would use profile label).  Then build the label the way you want to see it in the label composer and copy and paste that into your band style.  I have found that this little hack tends to work for several pieces in C3D that do not have expressions available.  It's just a matter of tinkering and finding the one that will let you do it.
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
in reply to: kcobabe
Not sure what "if-then" parameters one would use, espeically if you had to hack an expression from another label style.
Joe-Bouza
Can you not use an expression for the text height in the label style? similar to : if(profileelevation i=0 , 0.08,0)
Joe Bouza
Rail Community
