Hi all,
We have recently installed Civil 3D 2014 Service Pack 1, and while for the most part it works great, we are noticing one significant issue with profiles. In particular, when we have a design profile actively selected with grips showing, and then select one of the grips, the PVI you are editing becomes offset from the cursor. When you select a point with the cursor, the profile syncs back up as you would expect. This is a hard one for me to describe, so I have attached a screen shot to help clarify what is happening.
Has anyone else seen this issue? Just thinking out loud, but it seems like it would be some sort of graphic card issue, but we are seeing it across multiple machines. Any other ideas?
Thanks in advance for any help!
Sincerely,
Andy Reese
Civil 3D 2014 SP1
Solved by areese9779. Go to Solution.
Seems to work just fine for me.
Basic troubleshooting questions:
Multiple files on the same computer?
Same file on multiple computers?
Works here too but is it possible that the reason your cursor is moving off the PI is due to a PI in close proximity to the EVC?
Hard to tell from your caption but it looks like there may be a PI a very short distance to the right of the curve?
The cursor will leave the PI when it's unable to solve a curve such as captions below but this is expected as I've got to curves that only have 5' of tangent between them.
Above the cursor stays in grip but below I've exceeded the limit to the right.
Hi Andy,
This was drving me nuts too awhile back. It wasn't just with SP1. There is a bug with the Frist View style. See below:
Hi Brian - thanks for the response!
In looking at your screen capture, it appears you have the same thing occuring that I do, which is a separation between the cursor location and the PVI that you are editing. Additionally, when you have started the grip edit, it looks as though your entire profile has shifted, rather than just the PVI and two tangents you are editing. Maybe I am just seeing that incorrectly though.
As for your follow up questions, I can replicate this issue on any drawing with a layout profile on any machine with SP1. I cannot replicate it on any of the same drawings on computers without SP1.
Hi Jay,
Thanks for your response as well. The vertical curve dows not appear to be involved with the issue. I have taken two screen captures at a location without a vertical curve to better illustrate the issue. The first capture is from a computer without SP1 installed. The second is from my computer which does have SP1 installed.
Andy
Hi Fred,
It has been awhile! I hope this finds you doing well!
Thanks for posting the response you received from Autodesk. I looked at our profile view style, and the vertical exageration is set to 10. Also, our style is a custom style that didn't use the "First View" that Willy mentions. I also looked at our Elevation Range in the Profile View Properties, and it is actually set to automatic since I am in a design drawing.
Bummer - I had hoped you might be on to something for us!
Andy
This is where the bug is. Did you check here?
I did. When the elevation range is set to automatic, those options for the split screen aren't available.
No, there is no seperation. You can see the original location of the profile and the preview showing where the profile will end up when I'm done editing. As for it moving the entire thing, it's not. I'm just zoomed in close and the adjacent PVIs are quite a distance away so it appears that they are moving and not stretching.
That video is really helpful! It completely shows that yours is working correctly, which further adds to my mystery. On the upside of that, we are probably dealing with a simple setting issue. On the down side, I haven't the foggiest on where to start looking. I've tried toggling some of the usual culprits under the performance settings, to no avail. Any other ideas?
For those that are interested, I just tried using the grip edits for a pipe network, and had the very same thing occur. Image is attached. Very odd, to say the least.
Hi all,
So a man much smarter than myself (Thank you Ken!) was able to solve the riddle of what is causing the cursor to be offset from the profile while grip editing. It turns out that it is the Axis Offset of our profile view style. When there is a value assigned, the offset editing issue occurs, but when it is zeroed out, there is no problem with the editor.
Now, to just find a workaround...
Thanks everyone for your input and help!
Has anyone found a solution for this? My profile view styles are all 10:1 exaggeration in my DWG and the profile view style does not have split profile checked and there is not a split profile style in the dialog. This is a big issue.
specified. ecified.
Just the previous solution of zeroing out the axis offsets in the profile view style. Fotunately, we do our design in a different drawing than our production sheets, so the crappy way it looks doesn't ultimately make a difference.
This all worked fine in 2009 but was messed up starting from 2010.
Setting the Axis Offset to 0 does indeed fix the problem but it poses several others.
This is also a solution for having the grid lines double back on themselves.
I was hoping Autodesk would fix this after I contacted them about it in 2011, yet 3 years later....
Just started having this problem once I installed 2013 and SP2. Any fixes yet? It's any object in profile view that this happens. Can make it stop by setting offsets to 0, but this shouldn't be a permanent fix.
