Civil 3D Forum
Profile creation- Surface name
7 REPLIES 7
Message 1 of 8
GuillermoAQ
1248 Views, 7 Replies
Hi there,
How do I make my profile view to list the proper name of my surfaces, at the moment if I list my surfaces on my profiles they come up with numbers i.e. surface (1), (2) and so on. I would like my profile surface to show with their appropriate names.
Even when I go:
Create profile from surface and I add my surface tot the profile list it becomes Surface (#) instead of the surface name
Using Civil 3D 2009
Windows XP
Guillermo
7 REPLIES 7
Message 2 of 8
in reply to: GuillermoAQ
I don't know the details but you can't have profiles named the same. How are you trying to display the surface name?
Message 3 of 8
In the Toolspace, Settings tab, right click on Profiles & choose Edit
Feature Settings. Expand the Default Name Format tree & set up your naming
convention as you need.
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB
Vista64
Message 4 of 8
GuillermoAQ
Thanks for the quicks responses,
The issued is not naming the profiles. What I am trying to accomplish is to have the SURFACES cut on the profiles show up with its own names instead of a generic number.
For example if I have OG1 and I cut a profile of it and I listed on my profile it shows as a generic surface name (Surface 1) instead of OG1
Hope this explains it.
Edited by: GuillermoAQ on Jan 6, 2010 2:02 PM
Message 5 of 8
Go to the dialog I printed & post that.
I bet where you see
<[Alignment Name]> <[Sampled Surface Name]> <[Next Conter]>
in my dialog shows,
Surface <[Next Counter]>
in your dialog. Change Surface to <[Sampled Surface Name]>. As
Civil3DAnswers said, you will most likely need a counter to prevent
identical names unless you add another field that makes a unique profile
name.
John Mayo, PE
Radeon 4870HD 1 GB
Vista64
Message 6 of 8
You don't need a counter. If we find a duplicate name a (1) will be added
for you.
Cheers,
Peter Funk
Autodesk, Inc.
Message 7 of 8
GuillermoAQ
Thanks guys for all the replies.
John, that did the trick! Thanks very much for your reply.
Cheers!
Guillermo
Message 8 of 8
manny.rodriguezEU2ZG
I am trying to accomplish the same thing.  When I go through the steps described it changes the default name for when I create a new profile not the naming of the surfaces I am sampling in the profile view.  Any help would be greatly appreciated.
Rail Community
