AutoCAD Civil 3D General
boris.yordanov11
Message 11 of 19 (313 Views)
Re: Profile View data bands
03-31-2013 12:35 AM in reply to: troma
"Then set your band to use this profile as the data rather than the surface profile"
How does that happen?
*Expert Elite*
troma
Message 12 of 19 (297 Views)
04-01-2013 08:05 AM in reply to: boris.yordanov11
Click on the profile view (grid or band).
Right-click  > Profile View Properties > Bands
Change the referenced profile in the profile drop-down for the band.
Credit where credit is due! Give kudos or accept as solution whenever you can.
hillamng
Message 13 of 19 (277 Views)
04-06-2013 11:04 AM in reply to: boris.yordanov11
Hi Boris, Just like troma explains here, it works finally.
boris.yordanov11
Message 14 of 19 (259 Views)
05-11-2013 11:55 PM in reply to: troma
Hi troma
You explained how ot make the data "unrefined" but is there a way to make the profile itself less accurate. I found how to modify the distance between the ticks, but all it does is hide some of them, the graph at the top (the surface) remains unchanged.
*Expert Elite*
troma
Message 15 of 19 (241 Views)
05-13-2013 06:13 AM in reply to: boris.yordanov11
Are you talking about a surface profile or a layout profile?
Maybe if you attach some pictures it would help to see the difference between what you want to see and what you are seeing.
boris.yordanov11
Message 16 of 19 (227 Views)
05-19-2013 11:41 PM in reply to: troma
Check out the screenshot i attached. It would be nice if i could make the whole profile look more like the brown line, however what's more important is that the first section, between the those two signs, needs to be completely flat. Do you know how i can remove those lines i've circled. I found how to modify the space between them but i need them completly gone.
hillamng
Message 17 of 19 (221 Views)
05-20-2013 12:58 AM in reply to: boris.yordanov11
Right click your profile view and select edit profile view style. In the display tab, switch off the major, minor grids(See image below)
boris.yordanov11
Message 18 of 19 (215 Views)
05-20-2013 03:22 AM in reply to: hillamng
Worked like a charm. Thank you
*Expert Elite*
troma
Message 19 of 19 (207 Views)
05-22-2013 07:02 AM in reply to: boris.yordanov11
In terms of 'making the whole profile look like the brown line', you need to draw a profile 'By Layout' too. The red/white line on your screenshot looks like it is a surface profile, which naturally reflects the reality of the humps and holes on the surface.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
