I am attempting to create a profile view.
The grid needs to be 25m major; 5m minor for the horizontal. And 2.5m major; 0.5m minor for the vertical
Th only problem is, I only want the grid elevation labels to appear on the even elevetions not the 0.5m elevations.
Is there any way to do this?
Solved by Bill_Myron. Go to Solution.
Solved by Jeff_M. Go to Solution.
You can add text to the major and/or the minor and that's it. If your major is 2.5' and your minor is 0.5' and you want to label 1.0', I don't know of a way to do that.
There is one way, but it won't be automatic. Create a second PV Style (a copy of the one being used) that shows ONLY the Vertical Major Annotation, set the Major vertical grid to be 5. Add another ProfileView for the same station range and insert it on top of the first. You will likely need to adjust the elevation range manually.
I was hoping that it wouldnt come down to that. O well.
I have found another work aorund using the "Station + Elevation" label. I just removed the station and adjust the text placement. Insert it right at the edge of the profile. works great, and is also dynamic!
