When you both build the source drawing are you setting up the drawing for full design in that everything is setup and then placing it in a drawing that has another full design?
I have found that it is best to do a basic design in the source file. This should include the following:
Part List
Basic Style for structures & pipes
Then the drawing is shortcut into will need the following:
Final Style for what you want it to look like when you print
and that's about it. The part list, rules, etc... are not needed because they are set in the source drawing. All you will do is give yourself a headache when allowing the new drawing to mess with the objects as they come into the shortcut drawing.
All you should be doing is setting the view and label styles.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
