Distinguished Contributor
RickCarle-PE
Message 11 of 22 (480 Views)
Re: Profile Line and Band Text shift in Viewport
01-15-2013 06:07 PM in reply to: mikepo
Yes, we still have the issue. However, Output/Batch Plot can be trusted and does print correctly for us. [Description: signature 96dpi] Rick Carle, P.E. Director of Technology [Description: slice1][Description: slice2][Description: slice3][Description: slice4][Description: slice6]
taneum
Message 12 of 22 (456 Views)
02-15-2013 06:14 AM in reply to: RickCarle-PE
I am running into this myself.  My profile views are 10' hor. and 2' ver.  My drawing scale is set to 1"=10' and when I switch it to 1"=20' things change.  But when I am in paperspace, no matter what I do, unless my viewport scale is at 1"=20', the items I drew in by hand are shifted.  My original drawing scale was 1"=20' when I started the project.  There is something up with the whole drawing scale vs profile view scale vs viewport scale.  I just dont know what.
RickCarle-PE
Message 13 of 22 (453 Views)
02-15-2013 06:21 AM in reply to: mikepo
Still no fix in 2013.  This issue has been around for a while.  PLEASE FIX IT AUTODESK.  Fortuantely Batch Plot corrects it before printing, otherwise I would have been making a bigger issue out of this.
taneum
Message 14 of 22 (452 Views)
02-15-2013 06:23 AM in reply to: RickCarle-PE
Pardon the ignorant question but how do you batch plot then so I can get some sheets plotted out today?
RickCarle-PE
Message 15 of 22 (450 Views)
02-15-2013 06:26 AM in reply to: taneum
Go to the output tab and select batch plot.  Create your file list and then save it (optional).  It should be intuitive enough to figure out from there.  If not, read the help on it.
taneum
Message 16 of 22 (444 Views)
02-15-2013 06:39 AM in reply to: RickCarle-PE
Well, that didnt work either.  Set my viewport scale to 1"=20' and did a regen.  Looks fine.  Reset the viewport scale to 1"=10', didnt regen and batch plotted but the hand drawn items still come out shifted to the right by 5'.  I can manually move things in my profile view 5' to the left to remedy this but what a dangerous way to do design work.
I am pretty sure my drawing scale on the settings tab was originally set to 1"=20' when I started this project.  Why is it when my viewport scale is 1"=20' everything works fine?  Real freakin nice Autodesk.
mikepo
Message 17 of 22 (432 Views)
02-15-2013 08:33 AM in reply to: taneum
I finally got this submitted to the Autodesk developement and they're working on it. How long it will take to fix it, who knows. There is one thing to check that usually solves the issue.
In your profile view styles, check the right and left "axis offset" settings.(see attached pic)
If those settings are set to "0", for us at least that usually fixes the problem.
It means revising any profile view styles you may have set up, but if it fixes the problem, then I guess we live with it until Autodesk fixes it.
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
Win 7 Professional - 64-bit
HP Z400
Xeon W3550 @ 3.07Ghz
24GB of RAM
Nvidia GeForce GTX 760
taneum
Message 18 of 22 (430 Views)
02-15-2013 08:34 AM in reply to: mikepo
Yep just did this as I had actually written up a separate thread about it.  Got em fixed.
rdlongbow
Message 19 of 22 (243 Views)
10-17-2013 10:39 AM in reply to: taneum
I'm running into this in 2012. Does anyone know if this has been fixed in 2013?
Active Contributor
shunter62
Message 20 of 22 (233 Views)
10-17-2013 12:09 PM in reply to: SethHall
I am sure this issue is discussed in previous threads in this forum. From a post of a couple of years ago I found out that when you set up a profille view, the right and left axis offset settings in the grid tab should be set to 0. Here is the post:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Shifted-Profile-within-Profile-View/m-p/37593...
Having other values in these settings causes the viewport shift. I just corrected a profile this week with this method. Any additional notes or linework drawn in the profile view (such as an annotion to a crossing feature) prior to correcting the profile view need to be shifted back into place.
I hope this augments the solution posted in this thread. Otherwise, there's a whole lot regeneration going on.
Susan H
