dears
i want to add some lables in bands for proposed profile other than that of major or minor station lables.eg my major station are with interverl of 50m and minor station are 25m but i want to add lables in band like ground or proposed level at 39m. so what will i do?? Pleasee help me in this regard
regard + thanks
Habib Ahmed
Solved by tyronebk. Go to Solution.
What do you mean? At station equations, horizontal & vertical geometry is already avaliable you need to turn it on.
You can create profile labels which look like the profile band labels and annotate anythiinng you want then drag to the band.
What Mike is saying is that you can also call out data band labels at horizontal geometry, vertical geometry or station equation points, not just major and minor stations. If you want to force an elevation to be called out at 39m you can simply insert a PI, PVI, or station equation at the 39m mark, and turn on the labels and ticks in the display style. Pick which ever option makes the most sense for your situation.
You can also use other non-data band labels (profile view labels, profile labels, projection labels). Simply format them to look the same as the data band labels and place them at whatever station they are required.
