Civil 3D Forum
Profile Labels - High and low point
5 REPLIES 5
Harold_Alberto
1218 Views, 5 Replies
Hi all
I'm using Civil 3D 2014.
I have a profile low point label and want to drag it so a leader points to the low point of the profile line.  When I drag the label, the leader points to the middle of the vertical curve and not to the low point location.
I also notice that the text label anchor point is set on the VIP even if my setting is set to Anchor Curvey Low Point.
Am I missing a setting somewhere?
TIA
Harold
5 REPLIES 5
wfberry
in reply to: Harold_Alberto
What happens if you locate your Point Style for this Label and edit it.  On the Summary tab, change the LEADER STOPS AT MARKER  to NO.
I am guessing here.
Bill
Harold_Alberto
in reply to: wfberry
Thanks Bill but this is not the label from the Annotate ribbon tab. It is a profile label (select profile> right click > Edit labels...
Jeff_M
Harold
Nope, that's how this label works.
Jeff_M, also a frequent Swamper
Harold_Alberto
in reply to: Jeff_M
Thanks Jeff
... or doesn't work? Smiley Happy
Has it been like this on the previous versions?
I think it is a 2014 bug.  When I set the text anchor point to Curve Low Point, it anchors it to the middle of the curve.  The dragged state is also useless if the leader is pointing to the wrong location on the profile.
Jeff_M
It has been like this since C3D2004, AFAIK. If you have the High/Low point label in a separate style, i.e. not a part of the full VC label, you could set the style's leader to not be visible, then draw a leader manually from the high/low point and finally drag the label to that leader.
Rail Community
