AutoCAD Civil 3D General
Active Contributor
hmartinez5
Message 1 of 5 (336 Views)
Profile Glitch 2014 SP1
336 Views, 4 Replies
10-30-2013 01:59 PM
Hello everyone,
I have come across a very annoying glitch that is making me waste too much time.
We have two profile view styles we typically use, one is a 1:1 horizontal and vertical scale and the other has a vertical exageration of 6.
Enter the glitch. When I use the 1:1 everything works as expected, but when I switch the style for the one that has the exageration I can grip edit but the precision is awful and unexpected.
Good Profile (1:1)
Bad Profile (1:6)
The preview shows how the PVI to be moved shifts from the cross hairs and I can't snap to the exact location.
I have toggled OSNAP, purged, audit etc to no avail, even resetting Civil to the default settings. I have used the same styles on different drawings and it only occurs on this DWG.
Any ideas are welcomed.
TRogers
Message 2 of 5 (328 Views)
Re: Profile Glitch 2014 SP1
10-30-2013 02:09 PM in reply to: hmartinez5
Try turning off your tracking.  I noticed that you have the tracking on.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Member
kenm
Message 3 of 5 (322 Views)
10-30-2013 02:17 PM in reply to: hmartinez5
hmartinez5, see this post http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Profile-grip-edit-2014-Service-Pack-1/td-p/45...
The culprit is Axis Offset within the Profile View Style.  Change to 0 and all is well.
Active Contributor
hmartinez5
Message 4 of 5 (303 Views)
10-30-2013 02:28 PM in reply to: kenm
Thank you!
Valued Mentor
fcernst
Message 5 of 5 (283 Views)
10-30-2013 05:35 PM in reply to: kenm
I guess so... unless need to uset an Axis Offset.
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
