Hi all
Is there a way to make the Profile band title a specific text style? At the moment it seems that when I access
Profile Properties>Pick Band Style>Profile Data Bans Style>Compose Label>Label style composer
I go to the Contents (under Text) and edit it to bring up the Text component Editor.
In this if I go to the Format Tab the text style is set to annotative, however under that it says font style as an overide. How do I remove the override and set the style of the text to the text style. And how do i change the text style.
This is very confusing
Thanks in advance.
Nik
Create the text style using AutoCAD's Style command.
Specify the label to use the style: On the General tab of the Label Style Composer.
Hi Tim
Sorry for not getting back sooner. Will try that when I get chance and let you know how I get on.
Cheers
Nik
