So I created a FG surface by manually creating points over an EG surface.
Which runaway command or runaway commands do i use so I can use 'PSE profile station elevation transparent command so that a point on FG surface profile can be lowered or raised to look more like 1:1 slope.
Thank you
You can do that by inspection with a profile. Draw a design profile @ 1:1 and then determine the design elevation at the chainage requiring change.
I'd prefer to the transparent command , I was able to trigger the transparent command by creating a point first , a runaway command, I was not able to reproduce the action, I tried going thru each option creating a point but was not able to get to the step where red target appear to guide which elevation the small triangle should be place - parallel to elevation axis- . It seems make more sense to me create a uniform FG slope
It is probably way faster, than going to the FG surface and adjusting the points, or maybe that's better, I'm not sure.
Let me know anyway how to carryout the transparent command
thanks again
