AutoCAD Civil 3D General
Active Member
ascensojimer
Message 1 of 2 (126 Views)
Problems with scale in "presentation" sheet
126 Views, 1 Replies
03-29-2013 09:16 AM
Hello again,
I have another problem which I hope you can have the solution.
This time the problems are with scale, between "model" sheet and "presentation 2"
For example, in the following picture you can see one alignment in model sheet:
When I change to sheet model to presentation, it is shown:
I've tried to change text size, scale parameters... but there only shows this over-sized objets and text.
Anyone knows why happen this? What would I need to change to see it in the normal size? If I can't scale it well I won't be able to print it correctly!
I hope that someone will be able to help me!
Best regards
Distinguished Mentor
rl_jackson
Message 2 of 2 (120 Views)
Re: Problems with scale in "presentation" sheet
03-29-2013 09:29 AM in reply to: ascensojimer
In the first image I notice your scale looks to be at 1:1 you need to set the scale to some size i.e. (1:100 or 1" = 100") based on your units.
Then in Paperspace you set the viewport at the same scale and everything should be fine.
C3D12-13
Win7x64 6gb
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
