Civil 3D Forum
Problems with referenced layer colors
2 REPLIES 2
dslocum
229 Views, 2 Replies
I have changed a layer color in a file that is referenced into my base.dwg file. However, when I open the base.dwg file it still displays the layer in the previous color. Is there a way to automatically update the layer attributes in a reference file? or do you have to manually edit each layer attribute in every file that it is referenced into? I'm using Civil 3D 2014.
2 REPLIES 2
sirjoelsph
in reply to: dslocum
Try changing the VISRETAIN system variable to 0 and reloading your xref.
-JOEL
dslocum
in reply to: sirjoelsph
That was it! Thank you!
Rail Community
