Actually, have you taken a look at the Daylight Standard subassembly? You
can specify up to 3 different heights for this, specifying different slopes
for each situation. It should work I think.
Matt Kolberg
GCS - A Division of Cansel
wrote in message news:6318295@discussion.autodesk.com...
I am using the Conditional Cut and Fill to create the sideslopes for a
roadway project. I would like it to first try to meet existing at 4:1, then
try 2:1. To achieve this, I have two conditional fill subassemblies, both
set to a layout slope of 4:1. The first is set to Min Dist = 0 & Max Dist =
4 and has a 4:1 LinkSlopeToSurface end condition. The second has a min dist
= 4 and a max dist = 99999. This has a LinkSlopeToSurface end condition of
2:1. When I look at my sections, it appears that it is using 4:1 if it can
target the surface and then switches to 2:1. However, the distance
constraints do not seem to be applied. The 4:1 fills are very large. I
have read AUTOCAD help and looked at some resources online and I think I am
doing this the proper way. Am I missing anything??
