Civil 3D Forum
Problems in the corridor
6 REPLIES 6
arturopolanco
554 Views, 6 Replies
when build the corridor have this problem. there's a way of automatically correct
Arturo Polanco
AEC Solutions Specialist - Civil Infrastructure
Web | Moodle | Youtube | Instagram | Twitter | Facebook | MeWe | VK
6 REPLIES 6
Add drawing in CV3D 2012
Arturo Polanco
Joe-Bouza
in reply to: arturopolanco
Looks like you have to alter your region around the curve. Possibly remove the daylightand hand grade around the curve
Joe Bouza
arturopolanco
in reply to: Joe-Bouza
this is the only solution. have some 20 regions. is complicated and manually edit
Arturo Polanco
Joe-Bouza
Well you haveto change something, your grading criterior is simply not matching the location. How can the area round the curve be 30 regions?
Joe Bouza
Jeff_M
The daylights are overlapping. Copy the Assembly used in this area, change the daylight subassembly of the new assembly to omit the daylkight link, split the region between the stations where the daylights begin to overlap, use the new assembly for this region, set the surface targets, rebuild.
Jeff_M, also a frequent Swamper
arturopolanco
in reply to: Jeff_M
Jeff_M, send file to apol@hotmail.es
Arturo Polanco
Rail Community
