Civil 3D Forum
Problems in the corridor
6 REPLIES 6
arturopolanco
539 Views, 6 Replies
when build the corridor have this problem. there's a way of automatically correct
Arturo Polanco
AEC Solutions Specialist - Civil Infrastructure
Web | Moodle | Youtube | Instagram | Twitter | Facebook | MeWe | VK
6 REPLIES 6
Add drawing in CV3D 2012
Arturo Polanco
Joe-Bouza
in reply to: arturopolanco
Looks like you have to alter your region around the curve. Possibly remove the daylightand hand grade around the curve
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
arturopolanco
in reply to: Joe-Bouza
this is the only solution. have some 20 regions. is complicated and manually edit
Arturo Polanco
Joe-Bouza
Well you haveto change something, your grading criterior is simply not matching the location. How can the area round the curve be 30 regions?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Jeff_M
The daylights are overlapping. Copy the Assembly used in this area, change the daylight subassembly of the new assembly to omit the daylkight link, split the region between the stations where the daylights begin to overlap, use the new assembly for this region, set the surface targets, rebuild.
arturopolanco
in reply to: Jeff_M
Jeff_M, send file to apol@hotmail.es
Arturo Polanco
Rail Community
