I am currently using Autodesk civil 3d version 12 service pack 2 (Can't remember exact number) with windows pro 7.0 os. The problem that I am having is I would like to create a data shortcut for my finish surface but the data shortcut dialog box never comes up.
Here are the steps I take
1. Right click on the data shortcuts and select create data shortcut
2. Next it tells me you have to save the file
3. I click the quick save icon
4. In the comcand line it says q_save
5. I next try steps 1-5 over again and it always ask me to save the file but the menu pop up to chose the file will never show up.
Here is what I tried to trouble shoot the problem.
1. In my prospect tab under surface I do see a cooridor fg and a datum
2. My corridor.dwg file is roughly 4,3325KB
3. I have 28 data shortcuts no reference file
Any help to this problem would be appreciated.
Install the latest Service Pack for C3D2012. It fixes the shortcut issue (actually fixed in a previos SP, but you should have the latest one).
Thanks that worked
