Civil 3D Forum
Problem with the slope projection using a conditional subassembly
5 REPLIES 5
570 Views, 5 Replies
I am using an assembly with a conditional subassembly: If I have cut I will project a Daylight bench as you can see on the attached file, When I have fill, I am using a simple noise barrier , And finally a Daylightbench.
The problem is, the section is projecting the simple noise Barrier’s slope and not the slope of the Daylihgtbench.
Please see attached file to understand
5 REPLIES 5
sboon
About the only thing I can think of is that you have a Parameter Reference in your assembly which is taking the slope from the NoiseBarrier and applying it to the Daylight sub.  Another possibility is that you have a parameter override in your corridor.
Can you post the drawing?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
in reply to: sboon
Hi Steve,
Thank you for your help.
On my road I need to put a protective wall when I have a fill, there are another form to put a protective wall without use the nosebarrier subassembly?
the drawing file size is too large and I can't upload it here.
david.zavislan
Look at the help file for the SimpleNoiseBarrie subassembly. (You can access the help file by right-clicking on the subassembly name on on the tool palette.) It has an option to assign a target parameter that will be used to locate the toe of the backslope.  This parameter is optional.  Go into the corridor properties command and remove the target surface for this subassembly.
David Zavislan, P.E. | Wood Rodgers, Inc.
in reply to: david.zavislan
Yes, now everything is perfect, thank a lot David.
sboon
Good catch David.  Well done.
Steve
Steve
Rail Community
