AutoCAD Civil 3D General
Active Contributor
emmar0001
Message 1 of 6 (323 Views)
Problem with profiles
323 Views, 5 Replies
08-24-2012 06:56 AM
I created a profile the usual way and originally it looked as it should.
I then had to adjust the alignment (shortened it) but the profile now looks like this (attached). What causes this and how can I remove the empty stations to the right?
C3D 2010
Intel Core 2, Windows XP
2.67GHz, 3GB RAM
tcorey
Message 2 of 6 (312 Views)
Re: Problem with profiles
08-24-2012 07:51 AM in reply to: emmar0001
In the Profile View Properties, if you're using User Specified Range (Stations tab), the Profile View will not get shorter (or longer) when the alignment is modified.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Contributor
emmar0001
Message 3 of 6 (304 Views)
08-24-2012 08:20 AM in reply to: tcorey
HiTim,
Thanks for the response, but I checked in the Profile View Properties and it has the Station Range as automatic. Shouldn't then the profile update its stations when the alignment changes?
C3D 2010
2.67GHz, 3GB RAM
tcorey
Message 4 of 6 (300 Views)
08-24-2012 08:28 AM in reply to: emmar0001
Yes, it should.
I guess as a workaround, input your stations manually.
You don't possibly have another profile in that view, but that has a No Display style assigned? I'm reaching here...
Tim Corey, Owner
Redding, CA
BrianHailey
Message 5 of 6 (283 Views)
08-24-2012 10:11 AM in reply to: emmar0001
Change your drawing scale to a bigger number and I bet it fixes it. Your band in your profile view has a property set to stagger the labels if they overlap. Select your profile view and go into it's Profile View Properties. On the Bands tab, scroll to the right and you should see something like this. Set the staggering to No Staggering and it should correct it but the labels will then overlap. You could also change the major station interval in your profile view style.
http://screencast.com/t/lISCLlFdU
Active Contributor
emmar0001
Message 6 of 6 (265 Views)
08-24-2012 11:17 AM in reply to: BrianHailey
My God. Geniuses exist. Thank.You.Brian
C3D 2010
2.67GHz, 3GB RAM
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
