Civil 3D Forum
Problem with profiles
5 REPLIES 5
emmar0001
486 Views, 5 Replies
I created a profile the usual way and originally it looked as it should.
I then had to adjust the alignment (shortened it) but the profile now looks like this (attached). What causes this and how can I remove the empty stations to the right?
C3D 2010
Intel Core 2, Windows XP
2.67GHz, 3GB RAM
5 REPLIES 5
tcorey
in reply to: emmar0001
In the Profile View Properties, if you're using User Specified Range (Stations tab), the Profile View will not get shorter (or longer) when the alignment is modified.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
emmar0001
in reply to: tcorey
HiTim,
Thanks for the response, but I checked in the Profile View Properties and it has the Station Range as automatic. Shouldn't then the profile update its stations when the alignment changes?
C3D 2010
2.67GHz, 3GB RAM
tcorey
Yes, it should.
I guess as a workaround, input your stations manually.
You don't possibly have another profile in that view, but that has a No Display style assigned? I'm reaching here...
Tim Corey
Redding, CA
BrianHailey
Change your drawing scale to a bigger number and I bet it fixes it. Your band in your profile view has a property set to stagger the labels if they overlap. Select your profile view and go into it's Profile View Properties. On the Bands tab, scroll to the right and you should see something like this. Set the staggering to No Staggering and it should correct it but the labels will then overlap. You could also change the major station interval in your profile view style.
http://screencast.com/t/lISCLlFdU
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
emmar0001
in reply to: BrianHailey
My God. Geniuses exist. Thank.You.Brian
C3D 2010
2.67GHz, 3GB RAM
Rail Community
