I am using a assenbly with some condition like as you can see on the picture attached, but when I use this assenbly with my corredor on the secction view I can note the corredor don't used all the condition of the assembly, and as a consequently the daylight should not project as natural surface.
Solved by Ed.McGriskin. Go to Solution.
I am not to familar with conditional sub-assemblies but it looks like your assembly is working correctly on the right side but not on the left. Are targets set for the left side?
