Civil 3D Forum
Problem with Creating Alignment
3 REPLIES 3
jithukuttamath
338 Views, 3 Replies
 I have a problem when i create an alignment with Select Object. The Chainage is not coming properly.
And here i attached the Print screen, please see that.
3 REPLIES 3
The screen shot looks good.  If there are gaps left in the alignment, check to be sure the poly line is one entity.  I have had it leave gaps before when i had a section that was at a different elevation.  I don't do much work with the alignments, but since it's Saturday and you are working, I thought I would give it a go.
Surveyor Lee
What, exactly, is the problem? It looks fine to me, without seeing the alignment properties.
neilyj666
in reply to: jithukuttamath
nothing obviously wrong with this; any more clues?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
