I have a problem when i create an alignment with Select Object. The Chainage is not coming properly.
And here i attached the Print screen, please see that.
The screen shot looks good. If there are gaps left in the alignment, check to be sure the poly line is one entity. I have had it leave gaps before when i had a section that was at a different elevation. I don't do much work with the alignments, but since it's Saturday and you are working, I thought I would give it a go.
Surveyor Lee
