Civil 3D Forum
Problem export point from dwg file to txt file
6 REPLIES 6
yohanesseto.a.w
4795 Views, 6 Replies
hello all..
i have any problem about export point from dwg to *.txt file...
i have point file *.dwg from my friend,,but i confused why that point can't export, show warning "No point were transferred from the source"
point is in layer 0...I attach the dwg file..
Seto
6 REPLIES 6
I can't open the drawing because I'm still on 2012. The most likely thing that the points aren't civil points. List one and see what it says.
Allen Jessup
CAD Manager - Designer
karlkarpuk
in reply to: AllenJessup
I have the same problem but i don't know how to exactly sovle it. I attached a file where you can see 3344 points that i haev previously extracted from a surface. I need to export the coordinates of those points in PENZD format, but am getting the error "No points were transferred from the source".
What must i do to solve this problem? How do i turn the points into civil points?
karlkarpuk
in reply to: karlkarpuk
I am an idiot.
Points --> Convert AutoCAD points. Problem solved.
ksorsby
I've found that for large numbers of points, converting to cogo points then to a point file can take forever. There's a lisp file - ptexport.lsp - which creates an XYZ file directly from autocad points. It could be modified to give other variables I guess.
Kevin
Hallo,,karlkarpuk,,,
If now find such problems,,,i used other applications (sorry cad ^_^),,,for fast to convert thats point,,,
attach point your point
in reply to: yohanesseto.a.w
The file format "point.dwg" you send as autocad. not as cogo point, so you get problem with converting, you have to change format point as cogo point.
The file i have converted has been send as an attachment at format (PENZD) with the same name.
Rail Community
