I would try and audit on drawing2. Since it works for others, the method is
working.
Anthony Governanti
Autodesk, Inc.
Visit my blog: www.autodesk.com/wickedcoolstuff
I dig it! Do you? Join the Civil 3D Community Now!
http://civilcommunity.autodesk.com/
<3DCat> wrote in message news:5426879@discussion.autodesk.com...
I'm having a problem copying a grading criteria from one drawing to another.
For example, I'm copying grading criteria "GC1" in the Standard Set grading
criteria set from drawing1 to drawing2. (I"m dragging the criteria from
drawing1 and dropping it into drawing2.) It seems to work okay, but when I
look for critieria "GC1" in drawing2, it's not there under the Standard
criteria set (or any other set for that matter). I can copy the "GC1"
criteria to other drawings without any problem... is there something wrong
with the drawing I'm copying to (drawing2), or is there some setting I need
to change?
Thanks for your help.
