Civil 3D Forum
Printing problems with window mode in Civil 3D 2013
9 REPLIES 9
Message 1 of 10
wedzisi
1321 Views, 9 Replies
hi i have problem in civil 3D 2013 when i try to print with window mode , when i am try zoom in with mouse scrol printig function is disapiaring and after i must klick escape  several times for re use print eny one can tell me what is problem meby bug or  something
thx.
p.s. sory for my bad english
9 REPLIES 9
Message 2 of 10
Alfred.NESWADBA
in reply to: wedzisi
I can confirm that, but as I normally print using layouts and so not using "Window" to define the plot-area it's not something really hurting (for me).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 10
rkmcswain
Agreed. Known bug.
Message 4 of 10
AllenJessup
So a workaround would be to draw lines from or center circles at the point you need to pick for your window. Make them big enough so you can select them without zooming in and put them on a no-plot layer.
Or just plot from a layout.Smiley Happy
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Message 5 of 10
wedzisi
in reply to: AllenJessup
yeah you are right also i am ploting from lay out but somtimes i am geting lage drowings for ex. 13km road plan its tender document and the i need just som section i am ploting with window  thes is not so big problem but  somtimes i am forgeting and geting nervos 😄 so if autodesk will fix it will be beter
Message 6 of 10
civil
It says at the top of the forum this has been solved. Is there a hotfix for this one yet?
Yes I can get around it but still annoying..like docking a command line to get around glitches.
Message 7 of 10
rkmcswain
Message 8 of 10
mikeg
After hours of research I have yet to find a solution which fixes this problem. From what I have been told this issue has been resolved in Civil 3D 2014. Can someone from Autodesk please chime in on this subject regarding a upcoming HotFix or soltion to fix this problem.
Mike
Message 9 of 10
Alfred.NESWADBA
in reply to: mikeg
I'm not from Autodesk, but if I'm allowed to try it: I can't reproduce this issue with C3D2014 (German, Win7x64)
- alfred -
Alfred NESWADBA
Message 10 of 10
tddbuck
in reply to: Alfred.NESWADBA
One work around that works "sometimes" to get out of the loop is to right click and hit enter and it will give you back your pick appature.  It's not 100% but I have found it better than hitting escape 1000 times before starting the plot process over again LOL
Rail Community
