see how linking is happening between points along the same survey line?
any ideas how to prevent this?
Run some breaklines from one survey line to the other across the area where the TIN is interpolating incorrectly.
thanks, i tried the command "breakline" and connected 2 points across the 2 survey lines and all it did was draw a line with a "Z" in it and didn't seem to change the surface linking, sorry for my cluelessness but what is the correct command/procedure here?
