Civil 3D Forum
Prevent "3D Faces" objects when exploding an Alignment Tangent Label
1 REPLY 1
ginopalomo
219 Views, 1 Reply
I received a drawing where I have to add Bearings to an alignment and Right-of-Way lines. I have a Line Label Style that it works for that purpose. These new bearings are "Alignment Tangent Labels" and we need them to be "MTexts"
Select & explode once, and you get "Block Reference"
Select & explode again, and you get "MText"
Once that is done, unfortunatly, I get "3D Faces" objects in the background. Invisible on the drawing, but visible on paper once we plot them. The only way to remove them is by selecting around the new MText until I click on one, then, right-click, Select simnilar, Delete!
Is there any way to prevent that to speed up the process???
1 REPLY 1
troma
in reply to: ginopalomo
Is there a reason for exploding? I presume so.
Turn off the background mask in the label style. When exploded, the mask becomes a 3D face.
Mark Green
Working on Civil 3D in Canada
Rail Community
