I need to open this topic because i didn't found similar here.
So, i have a very big problem. I downloaded the C3D 2014, and trying it.
When i discovered the new function, i try to draw a pressure pipe network.
After i was take the design, there is no any object in the model space. Nothing.
There are a full list of pipes and structures in the tool space tree menü. When i just click the network name and select it, i get all of information about the planned network but i can't see any object, lines or other in the model space. All layout viewable,
What is the problem with it?
I didn't realize similar malfunction in this product after 6 years.
Thank you for the tip!
I try this network design on basic drawing template set, it called "Civil 3d (NCS) Metric".dwt
After it, the pressured pipe network is working very well! 🙂
I thik here is a problem with country specific template.
Where is the problem with it? How i can view the network (and the line or alignment under drawing) and all of data?
I try some basic setup in the country spec template in tool space, but i can't solved the problem with it.
If you have any solution, please tell me! 🙂
In the meantime i try to repair it...
I just sing in, and view this topic. So, i take a litle circle about this problem solving and i couldn't find any solution. All layer is turned on. All setting in the prospector tab is equal then in the bacis NCS template.
I just imported a liitle data to my country specific template and i attached it (2013 file format).
On the Task manager there is a pressure pipe network.
There is no any line on layout and long section. in the model space
What is the problem?
I am very frustrated... please help me if you have any working idea!
