Active Member
klesausk
Message 1 of 8 (582 Views)
Pressure Pipe Rules
582 Views, 7 Replies
06-29-2012 11:42 AM
I was wondering if you can create rules for a pressure pipe network similar to the rules that you can create for a pipe network.  I would like to create a cover and length rule for my system.  So far I saw that you can set a cover before drawing out the pressure network but I do not know how to edit that after the pressure pipes are drawn in.  Thanks in advance!!
Kit
Active Contributor
Avera737
Message 2 of 8 (566 Views)
Re: Pressure Pipe Rules
06-29-2012 01:34 PM in reply to: klesausk
To answer your question, I believe you can "apply rules" to a network and Civil 3D will do it's best to apply the changes you've made to the rules.
However, I don't recommend using pipe networks to do pressure systems.  There are a number of reasons why, but basically it's because you can do much more if you design the network with an alignment, profile, and, if you are feeling ambitious, corridors.
Civil4D (formally Civil3D) dot com has a great two part post on exactly this.  While I myself have never used a corridor to do the earthwork calcs I have used alignments and profiles to do my designs and drawings.  I'm sure you can play around with some styles and get it to look similar to the way your pipe network is being displayed now.
Keep in mind while this looks like a pain to setup, once the styles are set and you've mastered the work flow you'll fly through the next design.
Active Member
klesausk
Message 3 of 8 (563 Views)
06-29-2012 01:51 PM in reply to: Avera737
Thanks! Currently we do use alignments and profiles for our designs and it works great but with the 2013 having the pressure pipe network finally I was trying to see how it worked and if it would be applicable to our design.  Unfortunately it doesn't look like that's the case. Thanks for the video links though, I'll definitely try using corridors
Active Contributor
Avera737
Message 4 of 8 (560 Views)
06-29-2012 01:55 PM in reply to: klesausk
Look at that, learn something every day.  I had no idea 2013 came with a pressure network.  I'm still on 2012.  I'll have to check that out, I've got the 2013 disc somewhere.
Happy CADing!
Product Support
SethHall
Message 5 of 8 (515 Views)
07-02-2012 06:36 PM in reply to: klesausk
I think the design checks could be helpful:
http://docs.autodesk.com/CIV3D/2013/ENU/filesCUG/GUID-376BE040-9D47-4ACF-A419-CB8EE85B19BB.htm
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
Active Member
klesausk
Message 6 of 8 (499 Views)
07-03-2012 08:21 AM in reply to: SethHall
Thanks!! I had used that to check the cover initially drawn in but is there a way to change the covers and put a minimum or max slope on the pressure pipe network after the network has been drawn?  I know you can do this for the pipe networks for sewer lines and such but I can't seem to find it for pressure pipes.
Product Support
SethHall
Message 7 of 8 (466 Views)
07-05-2012 11:55 AM in reply to: klesausk
I don't think this is possible at this time as you have found. Feel free to voice your opinions about this by clicking here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Active Member
klesausk
Message 8 of 8 (462 Views)
07-05-2012 12:00 PM in reply to: SethHall
Thanks!!
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
