I have created a pressure pipe network (Plan view) from own created pipes and fittings, try to create an alignment from the network but C3D tells me that the selected network part has no connected parts?
How would I connect the network in order to create an alignment? (the pipe network has got a command to do that)
When creating an alignment from a pressure pipe, you must select the first pipe, then the last pipe on the pipe run.
Thanks, but that would not work because when I select my first pipe, pop-up comes up telling me that it has no connections, tried the next and next with same answer. So what I did was delete the first pipe and redraw it making sure that it connects to my fitting, and then only it works. I thought I had to redo my whole network but lucky for me, that was not necessary.
Thanks anyway!
