Is there anyway to remove a vertical curve or segements created to follow a surface? Currently if I want to go back to a straight run of pipe I have to delete the pipe and redraw it and add it back to the profile
At this time, once a pressure pipe is converted using the "CURVEPIPEINPV" OR "FOLLOWSURFACEINPV" commands, there is no way to convert them back to their previous straightened versions.
If you would like to submit this as an enhancment / wishlist item, please navigate to the link below and submit this to the project manager of that product (specified in link). This will help the PM and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Feedback Link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
You can straighten a curved pipe, just not a "follow the surface" pipe.
Take the circular grip and place it exactly half way between the ends of the pipe.
That funtionality has been logged as a wishlist item. In the meantime, here is the workaround to get the FOLLOWSURFACEINPV command to work for data shortcuts.
Workaround:
