I apologize in advanced as I am running of a few hours of sleep. I have a complex grading situation with a sewer near a drainage channel. Long story short.... I need to somehow look at my alignment section by section and try to establish a feature line that will represent my proposed top of slope. There are a ton of different constraints that I will not go into. My ultimate need is the ability to establish a feature line or 3d pline from the section view. I know that this is somehow possible via cooridors. Im working with just an aligment and cross secitons at every 25 feet. Is this possible? Maybe a "project objects to sections" only backwards?
You have two options which may work. If you have a sample line group and section views then you can project your featureline to the sections and see it there. I believe that you can edit the elevations through the section views, but you cannot move the points horizontally, so you would have to use two viewports to do the editing - one showing it in plan and the other showing the sections.
The other method would be to use the corridor section view/editor to do it. You would need a dummy corridor to follow but you should be able to grip edit the featureline at any point where the editor can see it. Keep in mind that you can only do edits at stations where the grip points are visible however. There was an AU class several years ago where Peter Funk used this method to create a featureline. He opened the view editor then started drawing a featureline, advancing from one station to the next as he drew it.
