Ok. If I follow the below mentioned and enter a +.5% during the drag state
is going the wrong direction but when I release it, it is correct. So it
does do what I want it to do. Still seems weird to me.
"Landman" wrote in message
news:41bddf63$1_1@newsprd01...
> Good Day.
> Looking for someone to give this a shot.
> Sample a profile from RIGHT to LEFT
> Start the line command
> Select the "Profile Station Elevation" transparent command
> Pick a spot on your profile for the Station and then the elevation and hit
> return one more time to end this transparent command
> Next choose "Profile Grade Station" from the transparent command
> Specify a grade of -.05% (Because I want it to go from right to left)
> You will see as you drag your cursor that it is sloping up as you travel
> from right to left (As expected)
> Now enter a station somewhere right of where you started (Lets say you
> picked at station 100 then enter 200)
> The grade of the line flips even though during the drag it is correct.
