Civil 3D Forum
Ponit Group when Importing Survey Points
5 REPLIES 5
437 Views, 5 Replies
All,
Sometimes when i import points Civil 3d creates a Point group in the drawing with the name of the point file, sometime it does not. I prefer when it does create this point group. It always seems to create a Survey Point Group. How do i control wether or not a point group is created in the import?
5 REPLIES 5
Sorry Civil 3d 2013, And i understand you can create them after the fact. My curiosity is why it sometimes doesent create them automatically?
rl_jackson
This all depends on how you insert the points into the drawing. If you want the point group to be created in the drawing with the same name as the point file, all you need to do is select and right click the *.txt file name in the point databases, and insert the points this will automatically create a group with the same name.
To create this automatically, go to the survey tab, select the survey user settings, and set the points to insert on import = yes
Rick Jackson
Survey CAD Technician VI
Nrhoads
in reply to: rl_jackson
I am importing through survey with an event and using a line code set to auto-generate linework.
I DO NOT want the point group automatically created. Is there a setting to keep it from creating one?
rl_jackson
in reply to: Nrhoads
Go to the survey user settings and set the points to insert on import = no
After you have inserted the point in the database, go to survey points, right-click and insert points - using this method will not create the additional group.
However, if you right-click the on the database at the file name level (*.txt) , and insert points, the unwanted group will still be created.
To me this is a major annoyance, that's been around since C3D12 (I think) as I can not remember v11 doing this.
Rick Jackson
Nrhoads
I have just been deleting that point group after I import but that is annoying too because sometimes I forget it's there and I'm like duh, where are my symbols??? Then it hits me!  They should have a setting to turn this on or off at least.
I also have a user defined point classification for notes (PNEZDN) and the NOTE isn't importing through survey but works fine if I import the points through prospector. Another annoyance...
Rail Community
