I remember in LDT there was way to create a pond database or something by selecting polylines. From there you could get a volume report, and areas of each contour. Is there anything similar to that in Civil 3D? I have about 40 new pond areas and would like to get some quick areas of each contour per lake and be able to view/print some kind of organized report.
Thanks!
Civil 3D 2009
Civil 3d 2012
Solved by ccoles. Go to Solution.
Solved by SethHall. Go to Solution.
Once you have the stage/storage data, press the 'Create Report' button on the bottom of the dialog box and it will generate a tab-deliminated text file for you. Do this for each pond, then you can merge that data into a single text file, word document, or Excel spreadsheet. I do it all the time.
