AutoCAD Civil 3D General
Member
Message 1 of 10 (198 Views)
Pond bottom does not show up in cross section.
198 Views, 9 Replies
04-10-2012 08:37 AM
After crating my squared pond (or waste landfill for that matter) I runned a cross section from an alignment running across the the entire pond. The cross section did not show the bottom of the pond. I noticed that I forgot to do an infill to the bottom of the pond so I did it. But, still the bottom of the pond its not showing up in the cross section, just the side slopes. Do I have to delete the alignment across the pond and recreate it? That is probably the only thing I have not done. BTW, I have an access road coming down the side of the pond with a corridor created already and is not showing up neither on the cross section. Please help, I am a senior student and want to graduate!
Regards!
PD: I am running Civil 3D 2012!
Message 2 of 10 (196 Views)
Re: Pond bottom does not show up in cross section.
04-10-2012 08:43 AM in reply to: jzrjimo
Is the pond bottom an even elevation? Is the line under your section view grid?
Select the section (not the view) and right click-draw order-bring to top.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Member
Message 3 of 10 (192 Views)
04-10-2012 08:57 AM in reply to: mathewk
Two corners are 0.01' lower by recommendation. When you say select the section you refer to the grid not the actual line? Does creating the infill after the proposed surface has to do anything with it?
Regards!
Message 4 of 10 (189 Views)
04-10-2012 09:00 AM in reply to: jzrjimo
When I say pick the section I do not mean the grid. You could select the gridd instead but you'll move that to the back of the draw order.
As long as a surface exists in the area of the infill, it will work.
Matt Kolberg
Member
Message 5 of 10 (186 Views)
04-10-2012 09:05 AM in reply to: mathewk
I'll try and let you know!
Thanks!
Valued Mentor
Message 6 of 10 (167 Views)
04-10-2012 11:44 AM in reply to: jzrjimo
Look under your grading tools for "create grading infill" and add that to the grading object
Message 7 of 10 (157 Views)
04-10-2012 01:07 PM in reply to: jzrjimo
In the OP's first post he mentioned that he did that. Unless he was speaking about something different.
Matt Kolberg
Member
Message 8 of 10 (138 Views)
04-10-2012 07:51 PM in reply to: jzrjimo
Ok, I tried but still just show the existing ground and the side slopes but not the bottom.
Please see image!
Regards!
Message 9 of 10 (135 Views)
04-10-2012 07:58 PM in reply to: jzrjimo
Does your surface actually exist in that area in plan?
Try resampling it if it does. If the section is not dynamic it will not update when you make a change.
Matt Kolberg
Member
Message 10 of 10 (128 Views)
04-10-2012 08:39 PM in reply to: jzrjimo
Thankssssss!
I went ahead and erased the whole section alignment and started over again and it worked. Still the access road did not show up but it is not really neccessary (I just wanted to show off a little bit).
I really appreciate the help!
Regards!
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
