I have a large drawing with a lot of information in it.
I am able to import new points, I am able to create points from a corridor.....but it will not let me enter in a new point manually.
When I go to enter a new point, it goes through all the motions asking for location, assigning a Northing and Easting and asking for a descriptor....but it does not show up in either the drawings or in the points listing.
I have purged, audited and shut down.
Any other thoughts? or has anyone else run across this?
Yep, it's an ancient bug that I think has been in every release of C3D so far...
Check your Next Point Number. If it's set to a number that is already in-use, then you get the behavior you describe.
If that's the case, why am I able to import new points and create new points from a corridor?
I don't see how you even list the next available point number in C3D 2012???
I copied about 50,000 of the points into a new drawing and it worked.
It appears I 'm going to have to work on drawing file management skills.
The drawing seems to get bamboozled with bugs if it's too big.
thank you for your help
@dolorespicard6832 wrote:I don't see how you even list the next available point number in C3D 2012???
From the Ribbon -> Home tab, select Points -> Point Creation Tools. Click on the chevron in the upper-right to expand.
50,000 Cogo Points is a lot. It's not so much that the drawing gets buggy, as performance gets slow.
In many cases, the reason for importing that many points is usually to create a Surface. If that's the case, you don't have to import the points. You can add your Point File to the Surface definition. That results in much better performance.
Oops, I might have answered the wrong question...
In C3D 2011 and later, to see what point numbers are available, click on Ribbon -> Modify tab -> Points, then "List Available Point Numbers" is in the "COGO Point Tools".
Prior to C3D 2011, you needed to write your own routine for this (or have a third-party package like the Sincpac-C3D). Or go look at the Points collection in Toolspace, and scroll through the list of Points to see which numbers have been used.
