elaine3051
Message 1 of 5 (174 Views)
Points set on Surface
174 Views, 4 Replies
02-07-2014 11:41 AM
I need to set a numbe rof points on an existing surface. Each point is giving me an elevation of 0.0 which of course is not the surface elevation. I'm sure this is a setting, but cannot find where the default setting is located. Thanks.
doni49
Message 2 of 5 (170 Views)
Re: Points set on Surface
02-07-2014 12:02 PM in reply to: elaine3051
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
Jay_B
Message 3 of 5 (140 Views)
02-07-2014 02:26 PM in reply to: elaine3051
Is Points Creation>Prompt for Elevations set to "Automatic"?
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
jmayo
Message 4 of 5 (133 Views)
02-07-2014 02:39 PM in reply to: elaine3051
You can also assign elevations to the points after creation from the Modify tab of the Ribbon click the Point button. When the Contextual Points Ribbon displays you will see a button for Elevations from Surface.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
jmayo
Message 5 of 5 (132 Views)
02-07-2014 02:41 PM in reply to: jmayo
When I set manual points I will typically create one point, copy it all over the place and then use that comand to save time on the command line.
John Mayo, PE
IDSP 2014
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
