Civil 3D Forum
Points not functional when saved down to 2010
4 REPLIES 4
kyle
207 Views, 4 Replies
I need to save my drawings down from 2015 to 2010, I have tried "save-as" and when I do that and open it back up, the points are not functional, they're just blocks.  I have also tried exporting the dwg as 2010 format, and that only bring in the nodes, but none of the other associated data.
4 REPLIES 4
jmayo-EE
in reply to: kyle
Civil 3D is not backwards compatable from 15 to 10. I belive we can only go back to a 2013 version and still have Civil 3D objects. You will need to export the points to an asci or xml file.
John Mayo
rkmcswain
in reply to: kyle
In 2015, export the points to LandXML, or an ASCII file.
In 2010, import that file ^^^
kyle
in reply to: jmayo-EE
but since I have a surface created in the drawing, by exporting the points, will it still be functional?
Cadguru42
in reply to: kyle
Exporting does not alter the existing drawings or database. Or did you mean the saved down 2010 drawing? That drawing won't have a surface because C3D is only backwards compatible between 2013, 2014 and 2015 (minus the bugs).
C3D 2022-2024
Windows 10 Pro
32GB RAM
Rail Community
