What you need is External data references, but it will need some tweaking to
use SQL Server
Another thing to look at is User-Defined Propeerty Classifications under
Settings->Point
Not a click-click solution, so it requires more time and space than I have
right now.
But possible.
Cheers,
Rad Lazic
wrote in message news:5414440@discussion.autodesk.com...
I have Civil 3D 2006. I am trying to display points from a table within a
Sequel Server database. Is it possible to link dynamically with C3d 2006 or
is it static? I have figured out how to connect to the database but not
sure how to display as points from a table.
Casey
