In Civil3d2010 when importing .txt file using Points>Create Points-Alignments>Import from File the points are inserted at the raw station value and not the station equationed (or actual station) value. However, when I insert them in the file using the Station/Offset command, they are inserted at the correct station equationed value when prompted for the station value.
Is there a setting so that the Station Equation value will be used for inserting from the .txt file?
