Civil 3D Forum
Point shift on convert Land desktop points
2 REPLIES 2
AllenJessup
1165 Views, 2 Replies
I had inserted a Land Desktop drawing containing points in to a C3D 2012 drawing. There was a small difference in coordinates. I used Autocad move and rotate to adjust. This was fine because I only needed a visual reference. Now someone wants the information and I need to convert the Aecc points to Civil cogo points.
The problem is that the convertldtpoints command doesn't use the location of the point marker as the coordinates for the converted points. It uses the Northing-Easting stored in the AECC_Point object. Those are the pre-adjustment coordinates.
Does anyone know a way of getting around this?
Allen
Civil 3D 2012 SP 2.1
Dell Precision T7400
Xeon CPU 3.16 GHz
Nvidia Quadro FX 4600
12 GB RAM
Win 7 Pro, 64-bit
Allen Jessup
CAD Manager - Designer
2 REPLIES 2
troma
in reply to: AllenJessup
I remember hitting this on one of my very first C3D projects.  My solution: note to self "Convert First, then Move"
Not sure if this is going to help you now though.
Mark Green
Working on Civil 3D in Canada
AllenJessup
in reply to: troma
That's near to what I ended up doing. I marked 2 solid points. Then I did the conversion and let the points revert to their original coordinates. Then I did a move and rotate based on the positions I had marked.
The only other challenge was selecting only those points I'd just converted and not points already existing in the drawing. I locked the layers that contained the points I didn't want to move and then used QSelect to select all the Cogo points.
Allen
Allen Jessup
Rail Community
