AutoCAD Civil 3D General
Valued Contributor
kolk
Message 1 of 3 (95 Views)
Point "Groups"
95 Views, 2 Replies
12-30-2013 09:33 AM
Okay, so not really a point group question in the way you think.  I have a drawing that we obtained from an outside entity and we are having an odd issue pop up:  when selecting a few points (this is a fairly large topo area) the propertires window states that they are a group of points, some "groups" being 3 points, some 7 points, and so on.  These "groups" cannot be Exploded or broken apart by any other means.  My suspicion is that the drawing was originally created in microstation and was "retrofitted" over to Civil 3D.
Any ideas on how to undo / break apart these groups?
Thanks!
Jay_B
Message 2 of 3 (92 Views)
Re: Point "Groups"
12-30-2013 09:41 AM in reply to: kolk
Thanks!
Could these GROUPS have been created using the AutoCad GROUP command?
Try the UNGROUP command on a small GROUP. Now are they normal entities?
If that works run the UNGROUP again but enter A (for all) when prompted to select objects
and UNGROUP all GROUPS in entire dwg.
Jay
C3D 2014 SP1
Win 7 Professional 64 Bit
Valued Contributor
kolk
Message 3 of 3 (86 Views)
Re: Point "Groups"
12-30-2013 09:47 AM in reply to: Jay_B
Thanks, Jay...that did the trick!
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
