I am working with a large site that is needing some grading changes. I also have a new addition to an existing building on this site. I have my overall site grading plan and proposed grading plan for around the new addition on the same sheet, separate viewports, separate scales. The proposed addition can be seen in the overall site plan, but I required additional detail around the footprint so I added the second viewport. I want to show my existing and proposed elevations on both viewports and I have a lot of survey points. I know how to setup my point styles and dragged point styles...etc. My issue is I can get the point labels to look good on my larger site plan (scale 1:1000) but when I look at the smaller plan (scale 1:250) the labels are a ways away from the point marker, I know this is because the label is annotative, is there an overide? I tried setting up a second point group for each existing and proposed (one set to work in the 1:1000 and the other for in the 1:250. Then since I required the spot elevations from the 1:250 in the 1:1000 still, I created new layers and copied the points to both so I could have viewport control of which style I saw. After I was all done it didnt work properly and I had spent a lot of time with no results. Was this close to right? Or is there an easier way?
If you plan on using points as your prefered labeling object...
If you plan on making surfaces and using spot elevation labels as your prefered labeling object...
I prefer the spot labels as I'd rather not have to deal with the survey database. If you NEED points and not spot labels, then you have little choice.
If you are using dragged states that are very similar for all your point labels in the detail area, you could make a label that has a leader as part of the label itself rather than added as when dragged. Just make it from a block and 2 lines. Then attach the text components to the end of the line. No matter what viewport scale you use the labels offset will appear the same. Only problem with this is that if you want the label to appear as different dragged states, you will need a seperate label style for each.
@Cirb9 wrote:My issue is I can get the point labels to look good on my larger site plan (scale 1:1000) but when I look at the smaller plan (scale 1:250) the labels are a ways away from the point marker, I know this is because the label is annotative, is there an overide?
The problem is more that C3D elements are NOT Annotative, but instead use their own unique scaling mechanism.
Annotative objects have the ability to be placed in different places for each scale. If we could do the same with C3D Labels, then you would have a relatively easy solution to this problem. Unfortunately, C3D Labels are still missing a lot of the functionality we now have with Annotative objects. Also unfortunately, things like MLeaders are also missing features from C3D Labels, so we can't always substitute Annotative Objects for our C3D Labels (although that's sometimes a good solution).
Matt and Andrew gave some possible workarounds. You don't really need a Survey Database for Matt's first suggestion, though... You can also use any other available method (e.g. Point Files, Copy-and-Paste) to get copies of your Survey Points into a new 1:250 DWG file, which you can XREF into your 1:250 sheets.
