Civil 3D Forum
Point and Link in creating subassembly from pline
6 REPLIES 6
995 Views, 6 Replies
I want to create a Section Type "Tunnel" from a pline: I have a closed polyline and I created the subassembly from it.
How can I add point and link in order to see the corridor as It should be (because with no point and link I see only the section in the corridor).
Vincent
6 REPLIES 6
KMercier_C3D
Using the Subassembly Composer additional software which can be downloaded with Civil 3D will provide you with more customizable control for making a custom subassembly, allowing you to assign point and link codes as well as Input Parameters much like the standard out of the box subassemblies.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
david.zavislan
Select the subassembly that you created from the polyline. Right-click and select the Add Code command from the shortcut menu.  Enter the code name, then pick the point, link or shape to attach the code to.  You will need to repeat this for every link, or point, on the subassembly that you want codes assigned to.
David Zavislan, P.E. | Wood Rodgers, Inc.
in reply to: david.zavislan
The problem is that I don't have any point to select (I have just the closed polyline).
david.zavislan
Edit the subassembly properties, on the Codes tab, assign a code set style that displays the points with markers.
Ok, now I see the points.
I add the code and select the points, right? Do I have to repeat these steps for every points (beacause it seems I cannot do multiple selection)?
david.zavislan
Yes.  Every point has to be done one at a time.
Rail Community
