R.K. McSwain wrote:
> In LDT, when setting up a DescKey where you want to import a symbol, you
> create your symbol at the desired plotted size, then in your DescKey
> table, for that symbol, under "Scale Symbol By", you check the "Current
> Dwg Scale" toggle, and that is it. (attached image 1)
> In C3D however, in Point Styles, when you select a block for your point
> marker, then select "Use drawing scale", you must enter a value in
> inches (attached image 2). What does this represent?
> In this particular case,
> the block is a 0.10 diameter circle, which
> requires me to enter "0.0025" in the "inches" field (drawing scale is
> [1"=40']) to get the end result of a 4 unit circle (which will plot 0.1
> at 1"=40')
> I get that 40 x 0.0025 = 0.10, I guess I just don't get why the
> additional value is needed. Why not just take the block geometry and
> scale it X the dwg scale....?
Why not have your block at a scale of 1:1 and just scale it based on
that parameter - take my tree block for example:
http://www.civil3d.com/index.php/2006/08/labeling-points-an-addendum/
Sorry we didn't get to talk in Vegas - I was really trying to find you...
Jason Hickey
Civil 3D 2007, SP3
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
www.civil3d.com
