Here is my dilemma...
I have a survey point for a Found Iron Pin.
Description Keys put's it on the correct layer for Survey Points
Point Style shows my Iron Pin Symbol
I would like the symbol to be on a layer that stays on when I freeze the point layer.
In LDD I had points on Z-Survey and the symbol on E-Survey then I could easily
freeze the point layers and leave the symbols in the dwg.
I've tried every setting I can find and I can't get this to work like it used to.
I know I can apply a style that turns off the point labels but that takes too many steps.
I have a macro i used to turn my Z-* layers
Suggestions?
C3D 2010
TIA
Bo
Solved by MtnMax700. Go to Solution.
It does seem odd that there isn't a setting for this (at least not one I've found). I too use a special point group with point marker and lable style to display my monument symbol and monument information. Like you, if I freeze the point layer, it turns off, eventhough the label display is set to another layer. It also turns off if I freeze that other layer too.
Sorry I can't help, but if you find the answer, I'd love to know.
If I'm understanding you correctly... within your point style, under the display tab, you have to set your "marker" which is the symbol to your desired layer and the "label" to it's desired layer. See attached.
sorry here is the attachment
This isn't LDD. The symbol is the node. I use v-node-mon for the symbol and v-node-text for the label info. Turn off v-node-text and symbol stays. Do something similar for all symbols.
David
Perfect!!!!
I had the point go to E-Survey and I created a style for my Iron Pin code (103) that
has the label set to Z-Survey.
Thanks!!
