Civil 3D Forum
Point Style Defined by Parameter $1
8 REPLIES 8
Message 1 of 9
JMichalik5844
479 Views, 8 Replies
I have looked high and low and can't find an answer to this.  Does anyone know if it is possible to have the point style for a shot match on Parameter $1 instead of $0?  For example on the following codes:
STORM MANHOLE
STORM INLET
I would like the Point Style for the first example be a manhole and the Point Style for the second be an Inlet.  As far as I can tell, there is no way to have it look past the first parameter "STORM" when defining the Point Style.  Is this correct?
8 REPLIES 8
Message 2 of 9
tcorey
in reply to: JMichalik5844
You're right. You would have to eliminate the space in the description. You can use _ or -, but the space tells Civil 3D that the description code is finished. It will read additional parameters for size and rotation values only. I can see where you're trying to go and that would be a nice feature....
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
JMichalik5844
in reply to: tcorey
That's what I was afraid of.  😞  I was hoping to simplify our coding process, but it looks like it may not work the way I wanted it to.  I was hoping I was missing some really cool and secret wild card or something.
Message 4 of 9
Todd Rogers
Message 5 of 9
Hey Todd!  Didn't figure you'd be in today.  Specifically, what I am trying to do is convert our existing codes (from the LDD and Softdesk days) to take better advantage of the .FXL file format supported by Trimble.  As in the example you posted, things like Trees are no problem.  I can set the one code 'Tree', to fall into the 'Vegetation' point group and assign the 'tree' symbol to it, put it on the Vegetation layer and then use the parameters afterwards for my label style.  What I was hoping to be able to do was create a master category i.e. STORM in which those points would fall into the Storm point group, on the Storm Blocks layer BUT then read parameter $1 (MANHOLE, GRATE INLET, BB INLET, etc) to define the point style associated with that shot. I can definitely use the underscore or dash option, it just doesn't allow me to re-use as much of my current setup as I would like.  Thanks for the help!
Message 6 of 9
tcorey
in reply to: ToddRogers-WPM
Thanks Todd. I learned something new today!
Tim Corey
Redding, CA
Message 7 of 9
ToddRogers-WPM
in reply to: tcorey
LOL...i learn something new everyday from all you guys!!
Todd Rogers
Message 8 of 9
SurveyorLee
yes,
use STORM M* for one
and STORM I* for the other
You may have a 6 character restriction.  IF you do, change it to "STRM M*" an STRM I*
I use STMH and STMI to differentiate them.
This should work.
Surveyor Lee
Message 9 of 9
Hey Lee,
Thanks, I think that is what I will end up doing.  Not as clean as I would have liked, but still an improvement!  Thanks!
Rail Community
